lt1 newb
Old Mar 22, 2010 | 11:21 PM
camarofreak89's Avatar
lt1 newb
alright so im new here and im building a lt1 for my 89 camaro and im wanting to runn 2.02 intake valves and im wondering where i can find some because i didnt no if there any differnt from a normal 2.02 and im also wondering valve stem size differs or what
so any suggestions would be appretiated
also looking into another camshaft then what i already have
what kind of lobe seperation do they like and duriation?
Old Mar 23, 2010 | 05:31 AM
Guest47904's Avatar
Guest
Those are common SBC 11/32 stem sized valves. Gona be a bit pricey to change your heads from 1.94 to 2.02. Doubt you will see the full benefit of changing it.
Stock LT1s in F bodies had either 116 LSA or 117. LT4's had 115 LSA.
Duration varied from 200 to 210.
Old Mar 23, 2010 | 08:17 AM
so u think it wont make a differnece by changing the valves?
even with a aftermarket cam
alrigh my cam has LSA 112 and duration .050 of 212int218exh
with a gross valve lift of .488int .495exh
do u think this cam is even worth putting in?
Old Mar 23, 2010 | 11:19 AM
RamAir95TA's Avatar
What are your goals? It's hard for anyone to suggest anything without knowing how fast you want to go. With a cam that small, you'd be able to run it on stock heads.
Old Mar 24, 2010 | 12:23 AM
I'm trying to build a street drag combo with decent fuel economy the cam I already have is a lil small for what I want it was in a 305 I used to have and had 2k miles on it n I'm. On a slight buget considering I'm in high school still n I'm 17 but I'm looking for a mild cam in it but sumthin tht give me some upper rpms and sum good power
Any suggestion on cams?
Old Mar 24, 2010 | 12:25 AM
And I'm tryn to build the car to run mid to high 12s
Old Mar 24, 2010 | 05:28 AM
Too large a valve without the corresponding correctly done head bowl work will not gain you any flow. The valve will be shrouded to the extent it may flow worse than a 2.00" valve. I have 500HP through a 2.00" intake valve. Bigger is not always better.
Old Mar 24, 2010 | 08:47 AM
alright so your saying im jumping the gun a little on the valves sense i wont have a large enough cam
also portin and polishing ive heard these are tricky heads to port and polich but i dont know why they would be much differnt from other sbc heads and ya also was going to do that the heads and manifold just gasket match them ?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
