LT1 missfire.
Old Aug 7, 2008 | 08:45 AM
  #16
383racecar's Avatar
well after replacing the icm the high rpm misfire seems to be gone now it dies coming up to a stop or idling sometimes, when it goes to die if i try and save it by giving it gas it still dies i put my injector test light on and paluse is there and will brighten up when i try and save it from dieing but engine rpm doesnt pick up, new codes now are high res failure and low res failure that all points to the opti!!!!!
Old Aug 7, 2008 | 10:01 AM
  #17
MarcR94v6's Avatar
you said you've replaced the opti twice already, have you been using GM optis? That really sucks, has anyone else had to replace optis in such a short period of time or gotten opti codes?
I don't know much about the mod, but have you considered LTCC?
Old Aug 7, 2008 | 10:07 AM
  #18
383racecar's Avatar
The first 2 the rotors feel off of,there are Accel optis. well i think the Icm fixed part of the problem and now i just got a junk opti. Right now the car is running strong just will die at a stop now and again.
Old Aug 9, 2008 | 11:47 AM
  #19
383racecar's Avatar
well took the opti apart one screw feel out of the rotor again and i had put red lock tight on the screws before.
Old Aug 9, 2008 | 02:14 PM
  #20
IrocSS85's Avatar
ok dude, time to buy a new gm opti huh. hope thats the last of it.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
