Oil Cooler leaking????
Old Aug 8, 2008 | 07:45 PM
Finchinater's Avatar
Starting to get a sizeable oil leak and think that the oil cooler is leaking. Is there a gasket, can I tighten some bolts to stop the leak?
Did a search and most threads were opinions on whether to keep it or not. I need to stop the leak immediately and need a little guideance. Does anyone have part #'s for the gasket if it exists and instructions on houw to fix it.
Thanks for all that reply.
Finch
Old Aug 9, 2008 | 06:51 AM
RUDEDOG's Avatar
Now is the perfect time to delete it. Don't be surprized if its full of trash.
Old Aug 9, 2008 | 03:55 PM
94arcticwhiteM6's Avatar
14087586 is the number for the gasket between the cooler and the block and you may need 2 of 10170112 if you take off of the cooler. its an easy fix. or you could delete it. your choice.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
