lt1 misfire
Old Feb 6, 2006 | 12:30 PM
green zr1's Avatar
lt1 misfire
anyone know how to tell if your opti spark has a bad cap and rotor or optical sensor, i'd hate to change cap and rotor then found out i need a whole new unit any information would be helpful
Old Feb 6, 2006 | 01:09 PM
Re: lt1 misfire
If the problem is with the optical sensor, it will set trouble codes for loss of low resolution and/or loss of high resolution pulse pattern. If its a high voltage section problem (cap/rotor), there are no direct trouble codes, but if your car is OBD-II you should be seeing the misfire code.
Might want to add a "signature" showing at least the year of your car. Most people will include year, make, modle, tranny and any major mods.
Old Feb 6, 2006 | 02:27 PM
1FstFormulaV8's Avatar
Re: lt1 misfire
If you own an OBD-I car, you're kind of in the dark. If you're willing and brave. Check the spark coming from the opti. Though, it might not be as effective if you have bad set of wires. What symptoms are you having with the car? We need to know before we can make a better diagnosis.
Old Feb 7, 2006 | 10:41 AM
green zr1's Avatar
Re: lt1 misfire
my car is a 95 z28 4speed auto, has no spark to number 7 cylinder change plug and wire 3 times still no spark and no trouble codes
AdsoYo
May 2, 2018 03:21 AM
Klypto
Mar 23, 2016 09:05 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
