LT1 Manifold question, bear with me please.
Old Jul 23, 2010 | 03:34 AM
RACEON's Avatar
If you take the throttle body off and look into the manifold right past throttle blade openings there are two round holes right inside towards center line on the bottom. What are they for? PCV?
Old Jul 23, 2010 | 08:24 AM
RamAir95TA's Avatar
Probably IAC. I can only think of one hole to look at when the throttle body is off...
Old Jul 23, 2010 | 10:29 AM
RACEON's Avatar
This isnt my manifold, but I circles the area and you can see a portion of the holes within the manifold. Its not IAC, as those holes are little and within the actual runners. The main feed for the IAC is up front.
Old Jul 23, 2010 | 11:41 AM
Blow air in the PCV vacuum port below the throttle body bores, and see if the air comes out of the two holes in the intake.
Old Jul 23, 2010 | 03:01 PM
RACEON's Avatar
I will try it this evening. Thanks,
Old Jul 23, 2010 | 06:52 PM
RACEON's Avatar
Yep, its part of the pcv system. So, we need to make sure our PCV system is in proper working order to ensure no vacuum leaks can be attributed to it.
Old Jul 24, 2010 | 06:30 AM
The PCV system is an intentional vacuum leak. But if you have the system hooked up the way the factory designed it, it is pulling in air from the throttle body that has been filtered, and accounted for by the MAF sensor (unless you have a 93.... but you don't have a signature, so we have no idea if that's the case).
Old Jul 24, 2010 | 01:06 PM
RACEON's Avatar
I am a 93.
Old Jul 24, 2010 | 01:07 PM
You really need to add a "signature" after being here for 4 years.
Old Jul 24, 2010 | 01:08 PM
RACEON's Avatar
I will right now. Sorry about that.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
