LT1 MAF question...
LT1 MAF question...
So here is the dealio, I have a 96 Z-28. I recently had a miss and a MAF code pop up so I cleaned it up with dielectric cleaner. Put it back in, did my plugs over to NGK TR55's that day as well. Started the car and ran decently. After putting about 50-75 miles on it, it started misfiring something aweful. Pulled the plugs and they all apprear to be fuel fouled. Car is running rich as hell. Is my MAF the most likely culprit? Appreciate any info.
Is it giving a code again??? I had an issue with the wiring on my MAF. It seems to happen on the latter years of the LT1 for some reason. Like mentioned above I would unplug it and see if it runs any different. At that point you can get an idea of what might be the problem.
formula218
Dec 2, 2014 04:27 PM
