LT1 Machine Work - 383 Solid Roller Build
Old Jan 19, 2010 | 12:19 PM
  #16
4-RILLA's Avatar
This thread is
Old Jan 19, 2010 | 08:23 PM
  #17
stockssn2o's Avatar
Originally Posted by AdioSS
stockssn2o's posts seem dead on
thanks i only did it for 4 years lol i'm glad to know i learned a thing or two
Originally Posted by 96SSIndeed
I've heard that sometimes the studs had a problem of backing out over time. You heard anything about that?
Also glad this thread was started, i'm getting a lot of good tips on what to have done to my block when i take it to the machine shop
i've never seen any arp studs back out ... if they are installed right( read the instructions it says install hand tight then torque to XX ft lbs with moly lube or motor oil and i reccomend moly lube)
Old Jan 19, 2010 | 10:10 PM
  #18
94FormulaLT1's Avatar
I have built alot of dirt track motors over the years and thought I would through my 2 cents in as well.
Squaring the deck- Not needed for your normal rebuild. Once you start getting up to about 475 to 500 horses, it becomes more important that all the cylinders are at the same level.
Torque Plates - Again not really imortant for your grocery getter but as you start getting to the higher horse power levels it becomes more important.
4 Bolts - 2 bolt blocks should be good to about 425 to 450 horse power at less than 6K RPM. Standard 4 bolt blocks should be good to about 550 to 600 horses. Anything above that and there is no way I would use anything other than a splayed 4 bolt with arp studs n bolts.
O-Ringing - This maybe old school but it still has its place. Vehicles that are running agressive amounts of boost are normally still o-ringed. Won't find many vehicles running 30 plus pounds of boost that aren't o-ringed in my experience. My machinist builds alot of truck and tractor pull motors and deals with some insane boost levels.
Old Jan 20, 2010 | 02:46 AM
  #19
96SSIndeed's Avatar
cool, i had just heard some stuff. The guy who was telling me that is a buddy of mine who worked for a very reputable engine shop that builds off shore race motors, so there is no telling where he has seen this before.
Old Jan 20, 2010 | 11:17 PM
  #20
Bersaglieri's Avatar
on an lt1 you don't need oil restrictors... just put the stock style oil galley plugs back in and it'll live forever they have no oiling problems there are a few tricks you can do to make oil pressure a little higher that we like to do but it's not necessary..... we do it when we clearance a block 5 minutes with a grinder and 10 more psi of oil pressure
Arp bolts should be fine i put them in my engine with mr gasket mls gaskets.... and i'm shooting for 800 horse at the wheels on bottle.... the studs are just better imo.... we've had no problems with head studs "sealing" an lt1 is just like a sbc in lots of ways the head bolt pattern being one of them and they generally don't blow gaskets
$1800 is a rough estimate i made up at the shop ... for all the machine work with splayed caps and assembling it thats install splayed caps, line bore and hone, bore, tp hone, deck, clearance, clean cam bearing freeze plug, balance, assemble race type shortbock
Speaking of the oiling. I dropped the block off at shop 4 today and he was talking about doing some "oiling tricks" since it's going to be a solid roller motor. I was in a hurry to get to work but he spoke about removing a plug near the oil filter area and running a line to the front of the block fot better oiling. He also mentioned about the oil restrictors and enlarging/cleaning up the oil drain back. He also touched on putting screens in the oil drainback incase a lifter broke and debris wouldn't enter the oil pan.
I'm currently looking at running the Milodon high pressure pump and pickup with the 30909 Milodon 6 quart pan. I'm not sure if the extra 10psi you speak of would be beneficial with a SR setup.
As far as decking, after speaking with a friend of mine in Texas, he explained a zero deck and Felpro 1074 head gaskets [.040] would yeild my desired dynamic and static compression ratio. I'd have to look up my long work, but I think that setup would give me 12.5x static and 8.6x dynamic with a given solid roller grind.
Sounds like most guys are doing fine with ARP head bolts, so I'll stick with those.
Pricewise I am currently looking at...
Splayed 4 bolt Mains - $550
Bore and Hone w/TQ plate - $150
Square Deck - $200
Hot Tank/Mangaflux - $60
Cam Bearings/Freeze Plugs - $50
Total: $1010
If you added...
Clearancing - $75
Assembly - $200-$300 (depending on how far they assemble)
Balance - $200
Total: $1585
So that total isn't far off from what you quoted with all the work added in. I'm sure there are a few small things I will get done or checked that will add a little more to the total.
I appreciate the posts stockssn2o
Originally Posted by Kevin Blown 95 TA
My machine work was about $1800. It included a little head cleanup and I did all assembly. The guys were real nice but put the wrong main caps on there and didn't listen to me about getting the ones for pass side dipsticks so there was interference with that and I had to make it work because they didn't know what to do. They also told me my pan and windage tray wouldn't work, but I also made that work just fine. They apparently did a good job of the machine work though because I checked everything - the advantage of doing my own assembly. You never know when the machineist has a bad day or is hungover or sick or whatever and if he assembles the entire motor for you, he might hide stuff if he was unscrupulous. Not saying this happens often but not too many guys here bring their cars to the dealer for repairs for a reason and machine shops can have problems too.
It included:
Bake and blast the block
Magnaflux and sonic check
Bore & hone with plates & studs
ProGram splayed caps, align bore and hone with studs
Strap for the front cap
Deck the block
Freeze plugs, oil plugs, & cam bearings
Polish and lighten the crank
Balancing of rods, pistons, and crank
Fit piston wrist pins
Surface the heads
Clean and face valves and 3 angle valve job, pressure check, check guides & hone if necessary
I'll be calling the shop tomorrow and having him take note of the passenger side dipstick.
Good points about the machinist having a bad day or missing a few details. Granted it is there job, but we are all human.
I will do the assembly with a buddy or two that have done some pretty decent builds before [perhaps a certain Brut Funny Car] and we will be blueprinting the motor as well. Never hurts to have a second set of eyes checking everything over.
I got the same response from my friends who do frequent high performance builds.
Again about dead on with the word of mouth amoug my friends.
Being a "redneck" I can volunteer some info on O-ringing diesel motors. Although I'll have to disagree with 30lbs of boost needing O-rings since most factory diesels run 26lbs off the showroom floor. My Cummins for example runs well over 60lbs of boost on a stock head gasket and studs. Although boost doesnt kill head gaskets in our trucks, many times its the drive and cylinder pressures.
**Forgot to mention, when he was looking over the block he made a comment about the webbing on the passenger side of the block looked thin. I couldn't help but agree because it did. But after speaking with the shop he farms the splay cap work out to, they said they've done them before and knew about the webbing.
-Dustin-
Old Jan 21, 2010 | 06:20 PM
  #21
stockssn2o's Avatar
i've never seen that one... but maybe he knows something i don't... the tricks i was talking about are very simple and work well... 1. enlarging and cleaning up the oil drains 2. chamfering the oil filter hole and 3. enlarging and smoothing out the oil inlet on the rear main cap under the oil pump
the screens are a good idea
[I'm currently looking at running the Milodon high pressure pump and pickup with the 30909 Milodon 6 quart pan. I'm not sure if the extra 10psi you speak of would be beneficial with a SR setup..[/QUOTE]
Look into a kevco 7 qt pan they are cheap and work great and they come with a pickup ... i have one on my engine.... i used a meling select high volume pump in mine ...if your gonna drag race or have solid motor mounts you need a select pump
heres a picture...
not a problem
here some pix of my build...just because... its a shame i didn't even get it tuned yet and i'm pulling it back out to put heads and an intake on it ... its got 500 miles on it lol o yea once i looked at my pictures i thought of something else you might wanna do... get your machine shop to cut a keyway in your balancer hub.... its cheap insurance...
Old Jan 21, 2010 | 06:39 PM
  #22
stockssn2o's Avatar
Old Jan 21, 2010 | 08:09 PM
  #23
bombebomb's Avatar
I had forgot how much research I did before I had my engine put together, this brings it all back, that was a ton of research.
Old Jan 21, 2010 | 08:40 PM
  #24
LilJayV10's Avatar
There is a lot of good info in this thread. But I think who said if you are putting out more than 350 at the tires you need splayed caps is overkill but that is just my. 02
Old Jan 27, 2010 | 06:14 PM
  #25
69gto96z's Avatar
stockssn2o, is this the pan you used?
http://www.kevkoracing.com/images/1070_full.gif
Old Jan 27, 2010 | 09:25 PM
  #26
stockssn2o's Avatar
thats it... i called them and told them what i needed ... it was a shelf stock part... when you order it just make sure you tell him its a 1 piece pan and tell him if you want it zinc or painted black... nice pan for the price
Old May 6, 2010 | 02:49 AM
  #27
Rob94hawk's Avatar
Some good info here. Tagging this.
Old May 22, 2010 | 10:15 PM
  #28
Well after many months and a few setbacks the machine work is done. I've been blueprinting the motor over the last few days and I'll be updating this thread with additional information over the next week or so.
-Dustin-
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jrlt1
Jan 3, 2015 07:38 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
