LT1/LT4 Valve Covers
Old Jan 20, 2006 | 04:04 AM
kick Z tail out's Avatar
Exclamation LT1/LT4 Valve Covers
Where did you get your dressed up valve covers?
My friend got some very nice LT4 valve covers that clear the alternator, but he said he got them off of eBay. I like to avoid using eBay as much as possible.
Old Jan 20, 2006 | 05:48 AM
Guest47904's Avatar
Guest
Re: LT1/LT4 Valve Covers
I always loved these.
http://www.jegs.com/webapp/wcs/store...hItemId=279699
Not a fan of Jegs but they had the pic to show you.
Old Jan 20, 2006 | 07:42 AM
Yeah I really liked those too! My friend had those before he got the LT4 pieces he has now... The thing with those was that he had to cut the front of the cover apart over the baffle because it wouldn't clear the alternator.
Old Jan 20, 2006 | 07:52 AM
GreenZLT1's Avatar
I was going to try this place out.
http://www.performancechrome.com/
Old Jan 20, 2006 | 08:38 AM
Canton has a fab'd aluminum high rise cover with the notch for the alternator, and the correct oil fill and PCV vent tube connections.
http://www.cantonracingproducts.com/...overs/sbc.html
I've seen posts indicating you can fit the generic SBC center-bolt covers if you grind the alternator housing down a bit.
Old Jan 20, 2006 | 02:42 PM
Oh my goodness me want! Fred you rock.
Now, will that create any issues bolted over my stock valvetrain? I don't see why, but you never know. Low crankcase pressure or something... ?
Old Jan 22, 2006 | 02:32 PM
slopokrodrigez's Avatar
What do they call those, Franken-cover. Doesn't even make sense for stock.
Old Jan 22, 2006 | 02:39 PM
ABA383's Avatar
Those Cantons are some of the nicest I've seen...mmmmm...
--Alan
Old Jan 22, 2006 | 03:38 PM
6SpdLT1Z's Avatar
Nate, you can always move the altenator.
Old Jan 22, 2006 | 04:00 PM
If you don't like them, don't buy them for your car.... simple as that.
Old Jan 22, 2006 | 04:07 PM
89385formula's Avatar
Those covers are beautiful. slopokrodrigez....They are sheetmetal valve covers notched so you don't have to grind the crap outta your alternator, or modify a set of tall covers. You wouldn't even see the notch when the alternator is on.... So i would say it does make sense for those that want a nice tall sheetmetal set of valve covers that don't require modification.
Old Jan 22, 2006 | 04:19 PM
SStrokerAce's Avatar
Yeah I like sheetmetal covers as well!
Old Jan 22, 2006 | 05:30 PM
Janny's Avatar
There was a post on here a while back showing how to make almost any rocker cover fit. I used the info and put proforms on my car. Black wrinkle paint finish red bow tie. It took only a wee bit of grinding on the back of the alternater to make it work. No big deal.
Old Jan 22, 2006 | 06:33 PM
GMRL's Avatar
I realy like those myself, I was thinking of getting a pair but was concerned about clearance. Im not a big fan of chrome or polished metal. I like the black LT4s and the crinkles the best!
Old Jan 22, 2006 | 08:46 PM
The Engineer's Avatar
I would like to add the Canton fabricated valve covers, so I could use the taller ARP lock nuts on my 1.6 RRs. However, I have the ASR servo (driver's side) and I don't believe the taller cover will fit under the servo and bracket. Possibly, I could use spacers on the ASR servo bracket, but then there is the cowling directly above the servo.
I may have to say with my stock "chrome plated" valve covers.
http://www.cardomain.com/ride/2189634
