lt1/lt4
Old Mar 8, 2009 | 12:53 AM
95 WHITE TRANS's Avatar
lt1/lt4
Hi.Can i use my lt1 injectors and fuel rail lines on my lt4 manifold?
THANK YOU
Old Mar 8, 2009 | 03:14 AM
93FIRETURD's Avatar
yes you can they all are direct bolt ons.
Old Mar 8, 2009 | 08:28 AM
96capricemgr's Avatar
As I believe we already told you, the LT4 manifold is almost completely identical to the LT1 manifold. Difference is a little extra material above the intake port at the head flange.
Old Mar 8, 2009 | 08:57 AM
Are the lt1 injectors sufficent for the lt4 heads and lt4 hot cam?
Old Mar 8, 2009 | 10:23 AM
GM put 28# injectors in the C4 LT4's, and the LT4 didn't include the HOT cam. If you are approaching 400 flywheelHP, the 28 #/HR injectors, or larger make sense. You can "get by" with the stock 24's at that level, but the duty cycle will be above the normally recommended upper limit.
TRICK95
Mar 1, 2010 05:13 AM
SmoknZ28
Jun 22, 2004 12:03 PM
'95 LS1 Z28
West South Central
23
Apr 10, 2004 04:52 PM
'95 LS1 Z28
West South Central
15
Mar 31, 2004 10:58 AM
TRICK95
New England Area
Aug 26, 2003 01:09 PM
