LT1 lopey/rough idle - is this normal?
Old Jun 18, 2016 | 10:55 PM
  #16
deebee's Avatar
Re: LT1 lopey/rough idle - is this normal?
Originally Posted by Injuneer
The description of the problem seems a bit contradictory.... "at idle it seems a bit lopey/rough" vs. "I don't know if you can even hear it, it is so slight". I minor misfire, not on a regular pattern would seem like the most likely cause of the "I don't know if you can even hear it, it is so slight" issue. Marginally dirty/leaking injector, bad valve, faulty plug or plug wire.
The reason I stated you probably couldn't hear it is because it was suggested I take a video and I am not sure it will be noticeable enough but I am going to try anyways.
When I bought it it didn't concern me as I previously owned a 2002 SS and it did have a bit of a rough idle which I believe was due to the factory cam. So I assumed the LT1 had one too. The car runs perfect, doesn't stumble, pulls hard with no missing so it didn't raise flags. When I am sitting still such as at a red light is when I notice it.
I appreciate the pointers from everyone and it is a good base for me to start. Once this tank of gas is nearly gone I am going to start with injector cleaner and go from there.
Old Jan 27, 2021 | 07:40 PM
  #17
Andrew Kell's Avatar
Hey, I know this post is really old but this is a very similar problem to the weird misfire at idle that I have with my LT1. Were you ever able to figure out the problem?
Old Jan 27, 2021 | 10:50 PM
  #18
“deebee” hasn’t signed into this site in 4-1/2 years.
Might want to start a new thread, including specifics of your car - year, trans, miles, any significant engine mods. Not all years of the LT1 are identical.
Daniel6718
Oct 8, 2009 09:48 PM
HardcoreRM125
Mar 1, 2005 07:41 PM
SweetZRag
Sep 12, 2004 02:37 AM
93transam1234
Nov 3, 2003 12:50 PM
KLUCKS-SS
Feb 21, 2003 12:48 AM
