LT1 Long block Year made?
Old Feb 4, 2008 | 08:47 PM
Godchsr's Avatar
How do I figure out what year the motor is?
It's nothing more than a long block so that would be part 2 of my question... Since it's just a block and head can I build it for whatever year I choose or do I still have to stick with the original year it was made?
Then as a follow up question (sorry) If the above is possible, what would the best year to build be? OBD1/OBD2?
Old Feb 4, 2008 | 08:52 PM
96capricemgr's Avatar
There was only one block made for the LT1/LT4.
The 94-5 computer is the cheapest and easiest to deal with but the 96-7 can be good because of plugin testing as opposed to tailpipe.
Old Feb 4, 2008 | 09:33 PM
NovaTodd's Avatar
Does it still have the cam & timing set on it?
If so, a cam gear with a splined center hole is 92-94. Cam dowl pin is flush with the timing gear. Small center hole on the timing cover
95-97 (and LT4 timing sets) all use a longer pin coming past the cam gear. Large center hole in timing cover.
96-97 are OBDII and have the long cam dowl pin (long pin) and a crank position sensor on the timing cover. Large ceter hole in timing cover w/ sensor. If timing cover is missing, there will be a cogged wheel on the front of the crank.
Old Feb 4, 2008 | 09:54 PM
For the f-body, a VIN derivative is stamped on the block.
Old Feb 4, 2008 | 10:57 PM
NovaTodd's Avatar
Dang Rob you have EVERY bit of F-body info on your site. In case no one has every said it - Thanks for every bit of help you have given over the years.
Old Feb 6, 2008 | 11:04 AM
Godchsr's Avatar
I did some reading and came to the conclusion that OBD1 would probably be my best choice... well actually I just found a guy selling a 94 turnkey! hahaha SO I guess the choice was made for me.
Having said that I have, what was said to be, a 1996 LT1 Block and set of heads for sale... hehe (I couldn't verify the year or miles)
Old Feb 6, 2008 | 11:45 AM
There are different heads, with different head casting numbers. That might pin down the year.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Joes96z
Dec 13, 2014 07:48 PM
Jul 4, 2005 05:00 PM
guionM
14
Jun 19, 2002 08:30 AM
