lt1 lfters
Old Jul 21, 2014 | 09:50 PM
chuyz28's Avatar
lt1 lfters
Ok need some input going todo a cam swap on my z28 just wondering wich lifters to go with or will my stock lifters be ok have 150000 mi on motor thanks guys
Old Jul 22, 2014 | 11:15 AM
Chimera96's Avatar
Re: lt1 lfters
you should inspect carefully the rollers on your lifters. if good you can re-use......but cam companies recommend replacing lifters when installing a new cam
Old Jul 22, 2014 | 04:53 PM
bw_hunter's Avatar
Re: lt1 lfters
You can reuse them if you like but 150K is a lot of miles. You can use lifters for a
LS engines or even Caddy racing lifters. The GM sourced parts are reasonably priced. Three used to be issues with aftermarket lifters from Comp but I believe that's well behind us now.
Old Jul 22, 2014 | 05:00 PM
chuyz28's Avatar
Re: lt1 lfters
I looked up these part #12499225 will these work for my 96 lt1 will stock retainers nd spyder work with these if they do fit my car
Old Jul 22, 2014 | 05:28 PM
bw_hunter's Avatar
Re: lt1 lfters
Yes, those will work...
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
