LT1 and L98 crank - balanced the same?
Old Jul 21, 2004 | 11:18 AM
EddieP's Avatar
Is the LT1 crank balanced the same as the L98 cranks?
Old Jul 21, 2004 | 12:43 PM
Re: LT1 and L98 crank - balanced the same?
I was under the impression that the LT1 crank is lighter, because it uses lighter pistons/rods.
Old Jul 21, 2004 | 01:03 PM
EddieP's Avatar
Thanks for the reply shoebox. I think you're right, but do you know if the net balance is the same between the two motors (i.e., is the flywheel/flexplate counter balance the same)?
Old Jul 21, 2004 | 01:05 PM
Dont' know. I'm not an expert in this area, but there are some people on here that are. Hopefully some input will be forthcoming.
HectorM52
Jul 30, 2017 11:46 AM
Chevyguy358
Jan 28, 2015 08:04 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
