Lt1 knocking/ticking
Old Jul 29, 2008 | 07:42 PM
Reed44's Avatar
Just joined the site, heard there is alot of information on here. My car started knocking/tapping sunday night. I have good oil pressure, 60-80psi. You cant hear it really at idle but around 3k rpm it gets loud then gets quieter as the rpm goes up. The rev limiter is set at 6.5k and shift light at 6.4k. Shouldnt the mods it has handle that? I havent changed the oil yet to see for metal shaving.
Old Jul 29, 2008 | 08:36 PM
Reed44's Avatar
Just went and started it with the valve covers off to check the movement of the valve train and when I shut it off I saw the oil glisen with silver. Its done. The motor is getting pulle or dropped. Which is better? Out from the top or bottom? Where can I find detailed instructions on how to do this?
Old Jul 30, 2008 | 01:45 PM
95Blackhawk's Avatar
http://web.camaross.com/forums/showt...+engine+bottom
http://www.michiganspeed.com/enginepull/index.html
The bottom is what I did and loved it!
Here are a couple to get you started. It is quite easy once you get going on it. Suggest a 2 ton picker
Old Jul 30, 2008 | 02:09 PM
wrd1972's Avatar
Bottom
Old Jul 30, 2008 | 09:45 PM
Reed44's Avatar
Thanks for the info. I really appreciate it. Thats help me out alot.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
