Lt1 Intake Manifold Help
Old Oct 14, 2011 | 12:15 PM
ShowOff67's Avatar
http://shbox.com/1/pcv_pipe.jpg
ok so i know theres a senors that goes on the back right by the egr valve. so one line plugs into the egr valve and one into the intake? i think during the rebuild i lost some of the little lines. also there is a senors with two valves right next to the coil what plugs into them two? they look like the ends broke off inside of it will it really matter if all the little lines arnt connected. there is one line that runs from the left side it is under the small one that goes to the throttle body this one goes under the front of the intake and around the right side and does a 180 and turns up. what does this plug into?? i been trying to look on shbox but it seems my diagram on my radiator cover is different 1995 z28..
Old Oct 14, 2011 | 02:14 PM
Re: Lt1 Intake Manifold Help
http://shbox.com/1/egr1.jpg
http://shbox.com/1/opti_vacuum_conn.jpg
http://shbox.com/1/1995_evap.jpg
http://shbox.com/1/1996_evap.jpg
http://shbox.com/1/air_pump_recall.jpg
It is not clear what year your car is...
Old Oct 14, 2011 | 06:07 PM
ShowOff67's Avatar
thanks i needed the 1st link but could not find it on the site for some reason,
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
