lt1 honing ring and bearing question
Old Sep 2, 2004 | 09:58 PM
92rslt1's Avatar
Is honing re-ringing and main and rod bearings a good idea for a mid life lt1? i was going to do it just as a refresher. on another note .. can you use stock retainers with aftermarket springs??
Old Sep 6, 2004 | 12:48 AM
Dave Feerst's Avatar
Re: lt1 honing ring and bearing question
Well, the OEM bearings will easily make it to 150k 250k if you are religous with your oil changes. Piston rings will live just as long but performance will start to suffer as they wear. Most springs have a matched retainer for them. But if it is an OEM replacement spring im sure its ok.
oldschool
Feb 9, 2016 09:21 PM
1963SS
Feb 6, 2015 10:05 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
