any info on comp cams 304
Old Sep 3, 2004 | 10:33 PM
1_bad t/a's Avatar
I just bought it, and i just wanted to see what kind of gains i'll be seeing. I know its a small cam but for 300 installed. Couldn't pass up that deal.
Old Sep 4, 2004 | 11:19 AM
Bud M's Avatar
Re: any info on comp cams 304
Yeah, that is small. I'd be interested to hear your impressions of it, though.
Old Sep 4, 2004 | 03:12 PM
truedualws6's Avatar
The 304 is a 210/220 533/544 on a 114 CL w/1.6 rockers
The Crane 104227 is 210/224 511/553 on a 112 CL w/1.6 rockers
The 227 is a tad more, including the 112 CL will has a small but noticable lope.
I have the 227 and like it for my purpose which is a daily driver in traffic. The
304 will probably perform very similar and it's a noticable improvement over stock.
Probably about 30 rwhp.
Old Sep 4, 2004 | 09:02 PM
1_bad t/a's Avatar
well the person i bought it from had changed the lsa to 113 so it would bring the power band up a little. Do you have any time slips with yours?
Old Sep 5, 2004 | 12:03 AM
med_reject's Avatar
i have a cc-304. It made my idle a little rougher, and thats about all i noticed. Im sure it increased power, but not enough for me to notice a harder pull. For me, it was a waste of time and money.
I'll be going bigger.
Old Sep 5, 2004 | 12:54 AM
Z95m6's Avatar
FYI most people think the Hotcam is too small and wish they went bigger. I believe the hot cam is 218/228. Your is quite a bit smaller.
Old Sep 5, 2004 | 01:09 AM
Nothing yet, but I will dyno the car and post results. Not sure when as the
next few weeks are busy.
Old Sep 5, 2004 | 01:17 AM
'97SLVRBullet's Avatar
Okay, are you also going by the lift in this equation? 'Cause the hot cam is
218/228 525/525 Forgive me for being an idiot but what are you looking for when you say bigger....lift, duration or what?
Old Sep 5, 2004 | 01:53 AM
Z95m6's Avatar
It seems like a lot of the time after people do hotcams they wish they would of gone bigger. Well the hotcam is a lot bigger than the cc304. By bigger i'm going off of duration. Most people that run these smaller cams don't do heads and stock heads don't really gain any flow past .500 so getting a higher lift cam won't do anything.
Old Sep 5, 2004 | 02:53 AM
turbo_Z's Avatar
Right on brotha.
Old Sep 5, 2004 | 05:12 PM
1_bad t/a's Avatar
med reject,
do you have any time slips or dyno results with it?
Old Sep 5, 2004 | 11:44 PM
med_reject's Avatar
No I dont, sorry man. If it helps, i beat a TT supra with 15psi boost off the stock turbo with my locally ported heads and cc-304 and stock programming. I barely beat an ls1 vette with madz programming, and with stock programming i beat an M6 ss camaro with intake and exhaust, and it was close (a couple of car lengths from 60 to 120mph on a deserted highway). Thats the best i can give for perspective.
I have lost to every single head/cam f-body ive raced, and my problem is my cam.
Old Sep 6, 2004 | 01:42 AM
1_bad t/a's Avatar
well thanks for all the info, and i'll keep everyone posted on my results.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
Elcojoe
Nov 17, 2014 10:27 PM
