Lt1 Hesitation Kicking My Butt
Old May 7, 2006 | 09:41 AM
shaley1975's Avatar
OK 1994 TRANS AM STOCK LT1 MOTOR FLOWMASTER EXHAUST NO CAT , K&N FILTER NEW OPTI SPARK, FUEL PUMP AND REGULATOR CARRYING CORRECT FUEL PRESSURE , PLUGS AND WIRES , TPS SENSOR, EGR VALVE AND SOLENOID , NEW MAP SENSOR, OXYGEN SENSORS ARE OK TIMNG ADVANCE IS OK THIS THING HAS NO POWER FROM IDLE TO 2000RPMS AFTER THAT IT IS FINE UNTIL IT REACHES 5500RPM AND THEN STARTS TO MISS A LITTLE THIS IS DRIVEING ME NUTS ALSO HAS NEW GM FUEL INJECTORS. i BELIEVE THIS CAR SHOULD ROAST OFF THE TIRES OFF FROM A STAND STILL ANY HELP WPOULD GREATLY BE APPRECIATED.
Old May 7, 2006 | 09:49 AM
Honda Hunter's Avatar
Re: Lt1 Hesitation Kicking My Butt
The caps are killing me.
Old May 7, 2006 | 10:09 AM
Josh M.'s Avatar
So when you nail the gas from an idle...what happens?
Are you sure your plug wires, and especially your coil wire, and coil are good? Have you checked for arching in the dark with your hood open? Have you tried sparying your coil down with a squirt bottle of water to make sure that it is well insulated?
Old May 7, 2006 | 04:38 PM
my94blackz's Avatar
As for the problem, good luck major lt1 flaw
Old May 7, 2006 | 05:00 PM
StephenDeli22's Avatar
Bump for a similar problem
Old May 7, 2006 | 07:06 PM
TraceZ's Avatar
Is the throttle body clean? I've encountered LT1 hesitations off idle if the TB is dirty around the area of the Idle Air Solonoid. Make sure the IAS passages are clean, as well as the pintle of the IAS itself.
Old May 7, 2006 | 07:53 PM
shaley1975's Avatar
Originally Posted by TraceZ
Is the throttle body clean? I've encountered LT1 hesitations off idle if the TB is dirty around the area of the Idle Air Solonoid. Make sure the IAT passages are clean, as well as the pintle of the IAS itself.
Hey thanks for the info this is about the only thing I havent checked yet and thanks for not telling me its the opti i think thats is everyone quick fix
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
ced8
Jun 24, 2002 11:11 AM
