Lt1 heads
Old Oct 9, 2007 | 09:42 PM
z275plus's Avatar
Unhappy Lt1 heads
Would it be a good ideal to put a new or reworked set of Lt1 heads on a 95 z with 128,000 miles without reworking the bottom end ?
Someone told me that it would cause problems with the rings because of the added compression.
Old Oct 9, 2007 | 09:59 PM
speed_demon24's Avatar
I'm at 100k miles and I'm on my 4th cam swap and 2nd head swap so I say go for it as long as its in good shape.
Old Oct 9, 2007 | 10:49 PM
96capricemgr's Avatar
I put a set of heads and a cam in a 95K mile shortblock that had already been cammed for tens of thousands of miles and proceeded to beat on it for awhile till a bearing let go, compression was awesome though, cranked just shy of 230psi even after several thousand miles at 11.2-3 compression.
Not sure what to blame the bearing failure on but put a new spring in the second stock shortblock in hopes that it would better maintain oil pressure and keep this one alive longer, sofar so good.
The info you got is OLD school, modern engines do not wear the rings and bores the way older ones do, I would sooner worry about bearings. Oil pump springs can get weaker with age and heat cycles so a new spring in it is a good idea and fresh bearings if you want, but I would not mess with the rings.
Old Oct 9, 2007 | 10:55 PM
n2ceptor's Avatar
As far as the heads go, I wouldnt think it would hurt, unless they have been milled down and raises compression??????
Im sure someone with more info will chime in tomorrow on this one.....
Old Oct 9, 2007 | 11:05 PM
dangalla's Avatar
sure why not, at that milage i would already be thinking about a rebuild though. heads and cam will usually raise your operating rpm and put more stress on the bearings especially at high rpms
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
