lt1 heads
Old Oct 21, 2004 | 08:01 PM
1970z28's Avatar
lt1 heads
will a set of lt1 heads fit on a regular 350 block.
Old Oct 21, 2004 | 08:03 PM
ejfagala's Avatar
Re: lt1 heads
No, LT1's are reverse cooling
Old Oct 21, 2004 | 10:39 PM
bowtieman_racin's Avatar
Re: lt1 heads
I dont know how its done but there is a kit you can buy or possibly it's just a special head gasket that you can use to put lt1 heads on an old block, I've heard of a few people doing this with no problems.
Old Oct 22, 2004 | 02:41 PM
Re: lt1 heads
You need to weld up and redrill water passages.
Old Oct 22, 2004 | 02:53 PM
Red_94Formula's Avatar
Re: lt1 heads
It does not seem like it is too hard. Whats needs to be done is plug up coolant passages on intake side, port out coolant passages on deck side, drill a tap new holes for cross over in back of heads, the intake bolts are in differnt postions so they have to be drilled on the intakem. Thats about it. Plus a little bit of port matching.
To get great flow rates over 300 cfm at .500 lift with heads made for the LT1 cost a lot. The Dart Pro 1 heads flows 318/230 which is much better then anything anyone makes for the lt1 for only 2500 assembled.
Old Oct 22, 2004 | 07:33 PM
96capricemgr's Avatar
Re: lt1 heads
The Vortec heads all the Gen1 SBC guys love are basically a standard coolant flow iron LT1 head and will outflow most of the aluminum LT1 heads, plus there are pretty cheap NEW so it really isn't worth much hassle to modify LT1 heads to fit.
Old Oct 22, 2004 | 10:04 PM
1970z28's Avatar
Re: lt1 heads
thanks guys, that just killed that part of the swap.
Old Oct 22, 2004 | 11:01 PM
RE AND CHERYL's Avatar
Re: lt1 heads
As Dwayne said. Vortec heads are just LT1 heads that fit on a Gen I SB.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
