I was looking in my Haynes manual and it says 65 ft-pounds to torque them down to (of course in the pattern).
I was just double checking if that was right? I'll make one pass to snug them down, then another pass to torque them down.
2nd that. Three passes.
I would recommend doing in a three step no matter what just to ensure an even seal and torqing all the way around
Quote:
Originally posted by polcat1p
My haynes manual says 95 and earlier is 65 ft-lbs, and 96-97 is the three step process. I thought lt1 had the same block & heads from 93 to 97
Chad
The factory manual says 96-97 first pass 22 lb. ft., then short bolts 67º, medium and long bolts 80º. This is the method I think I will use when putting mine back together. The torque angle method is supposed to be more accurate than torque alone (and I think why the later manuals spec'd it). Of course, you will need a torque angle meter. Originally posted by polcat1p
Chad
Chad
would that be because the '96-'97 used torque to yield bolts? Originally posted by polcat1p
Chad
i'd assume Haynes is speaking of using GM bolts
EDIT: Shoebox, could you explain the angle method or shoot me alink where i could read about it?
The 'angle method' refers to going say the 67 degrees[of an arc/circle] past the 22 ft lbs point...etc..Originally posted by simple
