LT1 head torque spec's
I was looking in my Haynes manual and it says 65 ft-pounds to torque them down to (of course in the pattern).
I was just double checking if that was right? I'll make one pass to snug them down, then another pass to torque them down.
Originally posted by polcat1p
My haynes manual says 95 and earlier is 65 ft-lbs, and 96-97 is the three step process. I thought lt1 had the same block & heads from 93 to 97
Chad
Chad
Chad
Chad
i'd assume Haynes is speaking of using GM bolts
EDIT: Shoebox, could you explain the angle method or shoot me alink where i could read about it?
Originally posted by simple
would that be because the '96-'97 used torque to yield bolts?
