LT1 Head bolt same as regular SB?
Old Apr 7, 2004 | 07:32 PM
JONEZ_Z's Avatar
I want to order some ARP head bolts and i was just wondering if the old style heads used the same bolts as the LT1 or is there something different? Where is the cheapest place to buy some 6 or12 point ARPs? Also what are the advantages of using studs instead?Thanks.
Old Apr 7, 2004 | 07:37 PM
gb95zconv's Avatar
I belive they are different......I got mine from Thunder Racing.
Old Apr 7, 2004 | 07:49 PM
Serene's Avatar
Same type/length of bolts.
Old Apr 7, 2004 | 07:57 PM
JONEZ_Z's Avatar
hmmmmm. two different answers
Old Apr 7, 2004 | 08:09 PM
Serene's Avatar
they are the same. ill put money on it.
Old Apr 7, 2004 | 08:16 PM
Black6SpdTA's Avatar
Yessum.
Old Apr 7, 2004 | 10:12 PM
jtk's Avatar
jtk
LT1 head bolt sets have washers to protect the aluminum heads were as the old style bolts clamp right to the head serface. also later say 96 lt1s have a different tightening procedure called tourqe to yeld.
Old Apr 7, 2004 | 10:45 PM
Serene's Avatar
Um no.
Gen 1 SBC have aluminum heads too. Washers are not special to LT1. Call summit and ask for a set of bolts for a gen1 sbc and and lt1 and they will give you the same thing.
96 LT1s only have a different tightening procedure if you use a set of stock bolts. ARPs will be the same for all years. An lt1 is an lt1 is an lt1.
Regarding studs, you get easier head removal (well not in a 4th gen, but most cars you do) and better more even clamping force on the head.
Old Apr 7, 2004 | 10:58 PM
97WS6SCharged's Avatar
It's pretty easy to remove 4th gen heads with studs, as long as you remove the studs first.
Old Apr 11, 2004 | 04:01 PM
Prorac1's Avatar
. LOL, I like that, lol. The obvious answer no one thought of, lol. Prorac1
Old Apr 11, 2004 | 05:19 PM
96ZUL8TR's Avatar
i'm using the arp #134-3601, they are the same as the regular sb chevy. they come with washers if you have aluminum heads.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
