LT1 Head bolt same as regular SB?
I want to order some ARP head bolts and i was just wondering if the old style heads used the same bolts as the LT1 or is there something different? Where is the cheapest place to buy some 6 or12 point ARPs? Also what are the advantages of using studs instead?Thanks.
Um no.
Gen 1 SBC have aluminum heads too. Washers are not special to LT1. Call summit and ask for a set of bolts for a gen1 sbc and and lt1 and they will give you the same thing.
96 LT1s only have a different tightening procedure if you use a set of stock bolts. ARPs will be the same for all years. An lt1 is an lt1 is an lt1.
Regarding studs, you get easier head removal (well not in a 4th gen, but most cars you do) and better more even clamping force on the head.
Lt1son
Dec 31, 2014 01:35 PM
