LT1 Fuel Pressure
Old Sep 23, 2005 | 05:39 PM
Paul94Z28's Avatar
LT1 Fuel Pressure
I took my fuel pressure with a gauge. It is 39 PSI after pressurizing, 40 PSI at Idle, and between 40 and 47 or so when the throttle is applied. There is no bleed off when I shut the engine off.
Is anything wrong or is this about normal?
Thx in advance for your replies.
Old Sep 23, 2005 | 05:59 PM
Colin91Z's Avatar
Re: LT1 Fuel Pressure
Sounds pretty normal to me.
Old Sep 23, 2005 | 07:27 PM
1racerdude's Avatar
Right as rain.
Old Sep 23, 2005 | 11:15 PM
TCAL95Z's Avatar
I thought my GM Manual said that the pressure is supposed to go down a little with the engine started compared to the key on pressure?
Is this not important?
Old Sep 23, 2005 | 11:23 PM
1racerdude's Avatar
With the engine running and the vacuum line connected it should be 39. When ya pull the line off with the engine running it should be 41-47 all of this done at idle.
Tape the guage to the windshield and run the p*** out of it and the pressure shouldn't fall lower than idle with the vacuum line off.(41-47)
That is the checking procedure.
Old Sep 25, 2005 | 01:09 AM
TCAL95Z's Avatar
I thought you would know
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 10, 2002 08:54 PM
IDOXLR8
Aug 6, 2002 12:30 PM
