Lt1 fuel injector HP boost
i just got a 25th anniversary trans am and im looking to make this thing get a little over 350 bhp and i already started with cold air intake, bbk twin 58 mm TB, and full magnaflow exhaust -headers. i was planning on getting injectors but i have no experiance with them at all so i was curious about how much more HP soem 24lb injectors would give and what else i would have to do to make them effective if anythign at all.
I'm pretty sure the stock injectors are 24lb. Anyways... you're not going to be able to make more power with just changing out the injectors. I'd suggest a mild cam and a tune if you're looking for that kind of power. The mods you have so far are putting you on the right track. I'm pretty sure the stock injectors would handle that kind of power.
-Pete-
-Pete-
sorry i know nothing about injectors my friend just put some in his gt and he said he felt the extra power from them btu he got like 60lb injectors and that seems liek a little to much for me but then again idk what to do
The stock LT1 PCM can't adjust for larger injectors. So that would have to be tuned to correct. The only way you would pick up power is if you didn't have enough fuel to begin with and the larger injectors supplied that. 60lb injectors would support somewheres around 600+hp I'm running 42s on my setup. Hope that helps.
-Pete-
-Pete-
Stay away from the injectors till you need them. Bigger isn't going to do anything. Once you start getting more air into the heads, then you will need bigger injectors. The heads is where the power is.
Are you shooting for strickly a bolt on car or is heads and cam an option.
what else do you think i should do to first before i do anythign else to my car in order to get the most horsepower for the price
I havent got anything done ot the intake manifold yet i am going to buy an aftermarket one when i get the cash together but i havent looked into it much yet.
He asked about porting the intake manifold to 58mm because the stock holes in the intake for the throttle body bores are only 52mm. Putting a 58mm TB on 52mm holes isn't going to gain much. But then its questionable whether you really need to go to the 58mm TB with a basically stock engine.
My suggestion would be that before you start spending money on a 58mm TB and an aftermarket intake manifold, you take the time to put together a long range plan of where you want your mods to end up, then research what is required at each step along the way. Throwing money at unneeded parts is not the way to go.
Jul 4, 2005 05:00 PM
