LT1 Free Mod List......
Old Nov 28, 2003 | 06:11 PM
Camaro_Guru16NY's Avatar
Just curious as to what all the Lt1 Free mods are... So list as many as everyone can and how to do them if possible.
Thanks everyone,
-JOHn
Old Nov 28, 2003 | 06:17 PM
Heatmaker's Avatar
Advanced Member
There's only one "Free mod" that works and or makes a difference
TB-Bypass.
There's 2 hoses running along the bottom of your TB flowing coolant through it. You want to reroute them so they do not flow coolant through the Bypass. You can go to pepboys and pick up the hose joiner and the two hose caps to cover the exposed TB tubes. You can do it for $3.00 all together.
Like so
Old Nov 28, 2003 | 06:30 PM
drewstealth's Avatar
Yeah like he said. The only worthwhile free mod is the TB bypass. But then again removing some weight is a free mod and helps out quite a bit. The easiest is probably spare tire and jack. If you do this make sure you get a can of that fix a flat stuff. Also removing the front sway bar help out. But i'm not sure how much it is needed on a daily driver.
Old Nov 28, 2003 | 07:39 PM
leadfoot94's Avatar
If you do a search for free mods it has been asked many times. You will find more like the Air Temp sensor relocation, homemade ram-air, and stuff like that.
Old Nov 28, 2003 | 08:13 PM
terlox's Avatar
Why does GM have coolant running through the throttle body if the car runs better without?
Old Nov 28, 2003 | 08:16 PM
TheHeadFL's Avatar
Why do cars come with paper air filters and engine choking manifolds?
Seriously, though, its to keep the TB from sticking in the icy conditions up north. Or thats how the story goes anyway.
Old Nov 28, 2003 | 08:18 PM
ibanez6rg's Avatar
I think we all know TB will never get stuck because of "icey conditions"
Probably the same reason why GM has CAGS, rev limiters, and A4 shift blocks
Old Nov 28, 2003 | 09:58 PM
jasons93z's Avatar
You forgot the decreen the MAF mod. Some disagree, but when i did it i had better throttle response. I also P/P mine though
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Fusion93Z
Sep 10, 2002 06:46 PM
Thebeast431
Aug 25, 2002 05:06 PM
GC456
Aug 8, 2002 11:53 PM
Thebeast431
Aug 8, 2002 01:39 PM
