LT1 First Rebuild
Old Sep 27, 2008 | 03:55 PM
CKrawZ28's Avatar
LT1 First Rebuild
So I have a 1995 Z28 LT1 with basic bolt-ons. I've got Hooker Longtube headers into 4" flowmasters exaust, K&N Kit, underdrive pully, 3.73 rear end (rebuilt all internals), and an LT1 tuner. This car is my daily driver so I don't want to go too far. It has 80,000 miles and basically my valvetrain is getting a bit noisy, but it still produces a fair amount of power. I have a tick coming from the left rear cylinder under the valve cover. I wanted some advice on what I should do as far as a rebuild is concerned. Would it be okay to have the top end rebuilt, hardened pushrods, new rockers, lifters, cam, and freshen up the heads? I'm not looking to make a crazy ammount of power as this will be my daily driver. However, I'm trying to avoid having to pull the engine and do the bottom end as well. I've never built an LT1 or any 350 for that matter. Although I have rebuild smaller engines, quads, dirt bikes, and medium size tractors. I think with some direction I could do this myself. Any reccomendations would be greatly appreciated. References, parts, advice, etc. Thanks!
Old Sep 27, 2008 | 04:04 PM
LaredoZ28's Avatar
I'd pull the heads and have them resurfaced and have the valve ground. then put new rockers. a cam would b nice and help the power. I have the CC501 with stock pushrods, 1.6 rockers, and stock heads. that should get rid of the tick ur hearing..
Old Sep 27, 2008 | 04:24 PM
Rumblin70SS's Avatar
Make sure you diagnose that tick before you go any further. I had a tick in my motor we thought was a lifter. It ended up being a cracked piston that came apart ground everything to a halt.
Thanks,
Tony
Old Sep 27, 2008 | 11:51 PM
CKrawZ28's Avatar
Is there an easy way to tell the difference between valve train and bottom end? With the hood closed I can hear the tick bounce off the pavement. It increases and decreases with engine speed. It's definitely a ticking sound and not a knock. I also tried searching for an exhaust leak and couldn't find one.
Old Sep 28, 2008 | 04:59 AM
dStruct's Avatar
That's a tough one, I had both a valve tick and an exhaust leak on the driver side. The exhaust leak sounds JUST like a valvetrain ticking kinda sound, my leak was at the collector on stock headers, there's a 3 bolt ring and one bolt was um.. MIA lol. Needless to say it's come loose a few times and every time it sounds like a valve tick.
As for the valvetrain noise, I've got 177k on the clock and all my internals are still original, although noisy heh.. You might post a quick video on somewhere like Youtube so we can listen?
Good luck!
Old Oct 9, 2008 | 03:56 PM
CKrawZ28's Avatar
Okay I had someone else look at the car too. He confirmed that it's a lifter tick. So now I'm wondering what is a good cam to put with stock heads? I'm planning on going ahead with the top end rebuild. Whats a good list of compatable parts?
Old Oct 9, 2008 | 05:19 PM
96' Formula WS6's Avatar
I think the cc503 sounds perfect for your setup
Old Oct 9, 2008 | 05:49 PM
slomarao's Avatar
cc503, top end rebuild. 80k is nothing.
Sergio
Jan 27, 2016 04:27 PM
Vinceocratic
Jan 26, 2015 09:26 AM
Not Dave
Dec 11, 2014 06:32 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
