LT1 Engine Swap HELP..............
Old Jan 2, 2005 | 11:28 PM
ptown's Avatar
I have a 95 Camaro and I just had an engine from a 96 installed. It has a problem after it warms up,and you come to an idle sometimes the oil pressure drops and the check qauges light comes on.I was doing some reading and I think the 96 Engine has a lower compression than the 95. I used my ecm. Should I swap in the 96 ecm,would that fix the problem.Any help any one has I would be greatfull........
Old Jan 2, 2005 | 11:34 PM
Re: LT1 Engine Swap HELP..............
The computer won't have anything to do with the oil pressure reading. I would make sure the connection to the sensor is clean and tight and the wire is not pinched anywhere. Replacing the sensor could help as they sometimes act as you describe when they get old. It also could be that your newer engine has low oil pressure, too. Attaching a mechanical gauge for comparison purposes will tell you.
Old Jan 2, 2005 | 11:42 PM
ptown's Avatar
if the engie does have low pressure should I have the oil pump replaced. do you think it will do any damage to the engine the way it is now
Old Jan 2, 2005 | 11:55 PM
If it is truely low (not a false low indication), I would replace the pump. Though, it could be that there is a lot of bearing wear causing the low pressure. Low oil pressure is not good for any engine.
Old Jan 3, 2005 | 12:08 AM
ptown's Avatar
ive allread replaced the sending unit and the dealership told me to drive it for a while and see what happens.
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
