LT1 Engine Identification?
Old Dec 8, 2003 | 10:10 PM
  #16
madwolf's Avatar
The MAS connector is a 3 wire flat connector with a magenta o-ring.
The VIN is correct, trust me. I have verified that it was an original 6 speed car.
Old Dec 8, 2003 | 10:11 PM
  #17
87IROC-Zowner's Avatar
Ok... Well I found the 3 wire plug then on the driverside. I was looking for a 5-wire plug as is on my 3rd gen TPI.
Old Feb 17, 2020 | 08:00 PM
  #18
robertgun16's Avatar
Re: LT1 Engine Identification?
What IDs the 95 lt1
Old Feb 17, 2020 | 11:14 PM
  #19
From Shoebox:
http://shbox.com/1/block_vin.jpg
http://shbox.com/1/4th_gen_f-body_ye...onversions.pdf
http://shbox.com/1/lt1_water_pumps.jpg
Old Feb 17, 2020 | 11:21 PM
  #20
Thank's im doing a engine swap and I got the engine from eBay and there was a lot of things that the guy said about it but it wasn't
Old Feb 17, 2020 | 11:24 PM
  #21
Thanks. I'm doing a engine swap to my car and I had got the engine from eBay and the guy said a lot about it that it wasn't
Old Feb 17, 2020 | 11:27 PM
  #22
Like he said it was a 95 4l60e package and in the description it said the engine and transmission is good but I didn't get the transmission and my dad took a look at it when I had the k member to start the swap he looked and said it was for a manual transmission so I have to swap the wiring harness and ecu
Old Feb 18, 2020 | 09:49 AM
  #23
The 94/95 “ECU” (actually the PCM - Powertrain Control Module) is the same whether it’s for a manual or automatic. It can be flash programmed for either. The wiring differences are minor.
The K-member that supports the engine and front suspension is the same whether it a manual or automatic. Only the trans cross-member would be different.
If you plan to use a 4L60E, you must use a 4L60E that matches the program in the PCM. A 94 4L60E has a ”switched” converter lockup. A 95 4L60E has a “pulse width modulated” lockup. Later 96/97 4L60E's are not compatible because there are internal differences. The harness connector has a different number of wires between 94 and 95. Good reference post from another site:
4L60E year differences and interchanges.
Old Feb 18, 2020 | 10:09 AM
  #24
Ok I got a 94 truck transmission and also do you know if I need to swap the dash wiring harness and the forward lamp harness?
Old Feb 18, 2020 | 01:39 PM
  #25
I have no idea if the (unknown) truck transmission is compatible with your application.
All you've said is your "doing a engine swap". What are you swapping it into?
Old Feb 18, 2020 | 02:09 PM
  #26
The transmission came out of a 94 gm truck that had 4wd I had to that the output shaft from my old transmission and the tail shaft.
also I have a 95 Camaro that had a 3.4l v6
The thing's I know for a fact that u need is the fuel pump the wiring and ecu.
If there is anything else that I don't know about that I need let me know
Old Feb 18, 2020 | 02:10 PM
  #27
​​​​​​​If there is anything else that I don't know about that I need let me know
Old Feb 18, 2020 | 02:12 PM
  #28
  #29
Old Feb 18, 2020 | 11:23 PM
  #30
The transmission came out of a 4wd 94 gm truck I had to swap the output shaft and tailshaft
And I'm swapping into a 95 Camaro it was the 3.4l v6 and I'm putting a apparently 94 Camaro lt1
I know i will have to swap the engine harness an potentially the forward lamp harness and under-dash harness.
Do you know what else I need to change apart from the fuel pump.
List
K member
Differential
Driveshaft
Gauge cluster
Radiator
Radiator fan assembly
oldschool
Feb 9, 2016 09:21 PM
willismoons
Feb 14, 2015 08:42 PM
Jrlt1
Jan 3, 2015 07:38 PM
Jul 4, 2005 05:00 PM
