LT1 engeine specs
Old Jun 25, 2007 | 05:36 PM
MichiganSkip's Avatar
LT1 engeine specs
Where can I find the specs on the LT1 crank main and rod journals?
Old Jun 25, 2007 | 06:58 PM
rskrause's Avatar
Moderator
Just like every "large journal" small block Chevy.
Old Jun 25, 2007 | 07:07 PM
rskrause's Avatar
Moderator
IOW, you should look it up yourself, but I will make it easy for you (i.e. reward your laziness).
Crank journal #1: 2.4484-2.4493"
Journals :2 ,3, 4: 2.4481-2.4490"
Journal #5: 2.4479-2.4488"
Taper/out of round production: 0.0002", service limit 0.0010"
Con rod journal: 2.0978-2.0998"
Taper/out of round production: 0.0003", service limit 0.0010"
Old Jun 25, 2007 | 07:30 PM
I'm far from lazy. Stupid evidently , but certainly not lazy. FYI I did try searching but came up emptyhanded.
Thanks nonetheless.
Old Jun 25, 2007 | 07:37 PM
rskrause's Avatar
Moderator
You are nonetheless welcome
Old Jun 25, 2007 | 10:23 PM
In case you have more engine spec questions later... http://shbox.com/1/engine_specs.jpg
Old Jun 26, 2007 | 06:46 AM
Thank you !!
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
IDOXLR8
Aug 6, 2002 12:30 PM
