lt1 electrical problem, stop in...
Old Nov 20, 2006 | 04:27 AM
  #31
Guest47904's Avatar
Guest
You could ground out the signal wires and see if the PCM shows a voltage below 0.35 volts. This would prove the wiring and the function of the PCM.
Short the black to the tan/white and to the purple/white wires.
Remember when it's disconnected it should show 0.45.
Old Nov 21, 2006 | 10:08 PM
  #32
blackztpi's Avatar
so whaaaat? signal wires as in unplug the 4 weatherpacks in the pcm. i would assume the pcm is working fine since it did this on 2 pcms, this one being a new GM piece. i guess i need a step by step. but, here's what i know...car runs great in open loop. fuel trims cut out in closed loop. logically thinking, i need to look at all the items that determine short term fuel trim in closed loop. so what is most important???
Old Nov 23, 2006 | 01:00 AM
  #33
Dave1980's Avatar
It seems to test your harness out past the PCM will have to be done via voltmeter. I hate wires man, but trying to lead you in the right direction. Sometimes things can get melted by headers etc.
Old Nov 23, 2006 | 11:11 PM
  #34
blackztpi's Avatar
i have a feeling its something like that. i was out rompin on it for a half hour straight and the next day it started acting up. I'm hoping its something as simple as a burnt wire, or something.... u have a schematic of the power wire into the pcm?
liamcg97
Nov 25, 2019 05:55 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
Injuneer
Dec 15, 2014 09:36 AM
1LEThumper
Jul 14, 2003 12:45 PM
