LT1 deletions
Old Nov 30, 2010 | 07:12 AM
Myxtreme1's Avatar
LT1 deletions
So I got a real nice '97 M6 Convertible from a buddy of mine which needed a new head gasket. Took care of that. Well soon I would like to delete all the things I did on my '94. Mainly the EGR and the Smog system. Probably get a set of headers to aasist in that, but won't the '97 need to be re-programmed to get rid of that stuff?
Old Nov 30, 2010 | 07:16 AM
bw_hunter's Avatar
Re: LT1 deletions
Yes...or you'll have a constant check engine light. There are a variety of vendors on here that can help you with that.....
Old Nov 30, 2010 | 10:55 AM
Z28SORR's Avatar
Re: LT1 deletions
Nice choice!!! With the 6 speed you can go to a 3:73 or 4:10 rear ratio and not effect the gas mileage. You just use 5th and 6th more.
This really helps the heavy vert. get moving.
Old Nov 30, 2010 | 03:27 PM
Myxtreme1's Avatar
Re: LT1 deletions
Thanks. I think it will be a great daily driver. Speaking of gears and fuel economy, what do these m6 cars usually get mpg wise?
Old Nov 30, 2010 | 04:52 PM
bw_hunter's Avatar
Re: LT1 deletions
I get 17/24. used to do a bit better but took a hit with better tires. The Nitto NT555R2's were even worse....
Old Dec 1, 2010 | 01:02 PM
dirtgar's Avatar
Re: LT1 deletions
"Re: LT1 deletions
This really helps the heavy vert. get moving."
I also have a 6-speed, so you are saying that changing gears to a 3:73 or 4:10 rear ratio can make my z28 faster? all while not really affecting my gas mileage? If that's the case thanks I think that would be my next mod. I use my car on the streets mostly and have noticed that the only time I use 5th and 6th gear is on the highway and that is really rare. A change of gear ratio that makes my z28 quicker without compramissing driveability is exactly what I need! How much do the gears ussually go for and how hard is the installation process?
Old Dec 1, 2010 | 01:20 PM
bw_hunter's Avatar
Re: LT1 deletions
Originally Posted by dirtgar
"Re: LT1 deletions
Different gears won't make your car faster..it'll make it quicker.
If you don't do any highway driving today then switching to a higher numerical ratio won't hurt your fuel economy as you use the car. If you did a lot of highway driving, you'd see a decrease in mileage as the engine would be turning a higher rpm at any road speed, thereby using more fuel...
Gears run under $300 and aren't that easy to install. You might want a shop to help you do it as it takes a few special tools that you might not have....
Old Dec 2, 2010 | 10:22 AM
Z28SORR's Avatar
Re: LT1 deletions
But only a small amount. Even at 70mph, on the freeway, I was usually in 5th.
Old Dec 2, 2010 | 10:50 AM
GRIDERMAN87's Avatar
Re: LT1 deletions
4.10 is a good gear for the t56, (should have been an option), it will hurt the milage a little but 5, and 6 overdrives and are very tall might raise 6th a 300-500, rpm at 70, in 6th, but it might actually give you a reason to put it in 6
Old Dec 2, 2010 | 11:07 AM
bw_hunter's Avatar
Re: LT1 deletions
Agreed. I live in florida and the impact is small here as well..even at 80mph which is our defacto speed limit...LOL
DirtyDaveW
Dec 1, 2016 05:37 PM
alex5366
Mar 8, 2015 11:32 AM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
