LT1 deletions
LT1 deletions
So I got a real nice '97 M6 Convertible from a buddy of mine which needed a new head gasket. Took care of that. Well soon I would like to delete all the things I did on my '94. Mainly the EGR and the Smog system. Probably get a set of headers to aasist in that, but won't the '97 need to be re-programmed to get rid of that stuff?
Re: LT1 deletions
Re: LT1 deletions
Nice choice!!! With the 6 speed you can go to a 3:73 or 4:10 rear ratio and not effect the gas mileage. You just use 5th and 6th more.
This really helps the heavy vert. get moving.
Re: LT1 deletions
"Re: LT1 deletions
This really helps the heavy vert. get moving."
I also have a 6-speed, so you are saying that changing gears to a 3:73 or 4:10 rear ratio can make my z28 faster? all while not really affecting my gas mileage? If that's the case thanks I think that would be my next mod. I use my car on the streets mostly and have noticed that the only time I use 5th and 6th gear is on the highway and that is really rare. A change of gear ratio that makes my z28 quicker without compramissing driveability is exactly what I need! How much do the gears ussually go for and how hard is the installation process?
Re: LT1 deletions
"Re: LT1 deletions
If you don't do any highway driving today then switching to a higher numerical ratio won't hurt your fuel economy as you use the car. If you did a lot of highway driving, you'd see a decrease in mileage as the engine would be turning a higher rpm at any road speed, thereby using more fuel...
Gears run under $300 and aren't that easy to install. You might want a shop to help you do it as it takes a few special tools that you might not have....
Re: LT1 deletions
Different gears won't make your car faster..it'll make it quicker.
Re: LT1 deletions
4.10 is a good gear for the t56, (should have been an option), it will hurt the milage a little but 5, and 6 overdrives and are very tall might raise 6th a 300-500, rpm at 70, in 6th, but it might actually give you a reason to put it in 6
alex5366
Mar 8, 2015 11:32 AM
