LT1 Crank Hub Washer
Old Jul 5, 2012 | 11:54 AM
gelbza's Avatar
Does anybody know where to find one of these? It's no longer in production, and even with the part number I've been unable to locate one, or even a substitute.
Old Jul 5, 2012 | 11:55 AM
RamAir95TA's Avatar
Re: LT1 Crank Hub Washer
If you have the original one just measure the thickness, OD, and ID, and order the correct size washer from someplace like Fastenal, McMaster Carr, etc.
Old Jul 5, 2012 | 04:52 PM
97WS6SCharged's Avatar
Are you talking about a spacer to fill the gap between a 96-7 hub and the crank gear?
Old Jul 5, 2012 | 06:15 PM
gelbza's Avatar
Problem is I don't have the original, it had to be dremeled out (Long story). It's the washer that goes between the crank hub bolt and the crank hub, screws into the crank snout
Oh, and it's a 93
Old Jul 5, 2012 | 08:17 PM
ascastil's Avatar
Will this work.
ARP 234-2501 - ARP Balancer Bolt Kits - SummitRacingEquipment.com
I know you just need the washer but its a start.
Old Jul 6, 2012 | 10:12 AM
LT1inaMGB's Avatar
Go to your local pick and pull and unscrew one from one of the Chevy engines
Old Sep 15, 2012 | 09:36 AM
gelbza's Avatar
Thought I'd update this just for completeness...We finally found a dealer in Florida that had 2, so if anyone needs one look there first, there's one left. I also have the original (apparently it DIDN'T end up being sacrificed to the Dremel god), so if anyone's in a bind let me know...
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
