LT1 coil crisis.....
Old Jun 9, 2006 | 02:09 PM
wrd1972's Avatar
Okay my engine was stumbling bad from 5K-6KRPM a few weeks ago. I replaced the one year old Autozone coil with a warranty replacement Autozone coil. The stumble was completely gone, absolutely no trace.
Today I noticed a bit of the same stumble returning but not quite as obvious as the first time. Again this new Autozone coil is maybe two weeks old.
Can someone confirm that this Autozone coil I am using is total crap and is crapping out at high RPM? I assume it is OEM spec, does this sound valid?
Is the MSD blaster coil a good replacement?
Old Jun 9, 2006 | 02:57 PM
seawolf06's Avatar
Re: LT1 coil crisis.....
The MSD isn't that expensive, just replace it with that after you bring the autozone one back. Are you sure it's the coil?
Old Jun 9, 2006 | 03:12 PM
wrd1972's Avatar
Replacing the coil killed the stumble the first time.
Old Jun 9, 2006 | 03:13 PM
Mike96z's Avatar
Actually a better deal and more voltage get the Summit or Jegs brand blaster coils, I've used it and compared to the MSD they are alot better on the performance.
Old Jun 9, 2006 | 03:59 PM
wrd1972's Avatar
Just curious.
The summit coils is 48,000V
The MSD coil is 40,000V
It seems to me statistically the MSD is a better coil.
Am I off here?
Old Jun 9, 2006 | 04:41 PM
engineermike's Avatar
Originally Posted by wrd1972
Just curious.
Am I off here?
The MSD and Hypertech coils are identically and look strikingly similar to the OEM coil. They're all (except cheapo Autozoo) probably manufactured by the same company.
Old Jun 9, 2006 | 06:20 PM
wrd1972's Avatar
So you are thinking that this Autozone coil is an inferior product that is not on par with OEM or MSD?
Can anyone say with absolut certainty that this is the case?
Old Jun 9, 2006 | 07:53 PM
firebird84's Avatar
buying any electrical parts from autozone is a bad idea. Reason being the manufacturers dont warrenty any of the products it is warrentied through autozone themselves and therefore they are not as likely to get the best of parts if you understand what im saying. BASICALLY AUTOZONE COIL IS CRAP.
Old Jun 10, 2006 | 08:10 AM
wrd1972's Avatar
Good enough, I am going to order a MSD. I hope they got the bugs worked out of that coil.
maybe2fast
Feb 5, 2015 05:14 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Lt1son
Dec 22, 2014 10:58 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
