LT1 casting of heads?
Old Jan 9, 2008 | 04:45 PM
HottestZ28's Avatar
I have a stock LT1 in my 95 camaro what casting numbers do I probably have.
I am looking for a set to get ported what cast# do I want?
Old Jan 9, 2008 | 04:52 PM
This thread covers the two variations on the LT1 castings:
http://web.camaross.com/forums/showthread.php?t=427346
Old Jan 9, 2008 | 05:11 PM
HottestZ28's Avatar
it says that 94 have the good heads but not which ones, then it also says that 96-97 have 561 and they are bad for porting. I am guessing I have either 374 or 643 castings then.
Also are the 643's best for porting then?
Old Jan 9, 2008 | 05:31 PM
My 1995 has the 643 castings.
People tend to deal in absolutes. I am sure there are plenty of 561 heads that have been ported and I would not consider them "bad" for such. The earlier casting just have a little more meat on them for porting ease (as others have said).
Old Jan 9, 2008 | 05:46 PM
HottestZ28's Avatar
thank you for clearing that up for me both of you guys
Old Jan 9, 2008 | 05:49 PM
Stoopalini's Avatar
My '96 has the 643 cast heads .....
Thomas.
Old Jan 9, 2008 | 06:25 PM
MeanGreen97Z's Avatar
I've heard that too! My 96 had the 561s. I've got a feeling the early run of 96 LT1s got the 643s until they ran out and the later got the 561.
Old Jan 9, 2008 | 07:04 PM
Stoopalini's Avatar
FWIW, the mfg date on mine is 8/95 out of Canada
Old Jan 9, 2008 | 07:32 PM
I have no idea on mine... sold it. My 97 has 561s too.
Old Jan 9, 2008 | 07:33 PM
HottestZ28's Avatar
so if my build date was 8/95 then I have 643 which are good then right?
Old Jan 9, 2008 | 08:29 PM
Stoopalini's Avatar
My car is a '96 with a mfg date of 8/95. Your mfg date will be earlier if you have a '95. Easiest way to check is to take the driver's side valve cover off and look at the casting number in the head.
Thomas.
Old Jan 10, 2008 | 06:46 AM
...and where else would it have been from? All of our cars came from the same plant.
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
