lt1 cam in a vortec engine?
Old Mar 12, 2008 | 06:50 PM
blown94's Avatar
Would a Lt1 cam fit in a roller vortec eng from a '96 p/u? Besides the pin length, would anything need modified or is it a direct fit? Not wondering specifically for a stock LT1 cam, but he wants to upgrade so I figured I would see if I could use one of my other cams.
Old Mar 12, 2008 | 07:00 PM
mdacton's Avatar
yes it will work in 87-up factory roller block.
The snout is ground for the cam retainer....same as Lt
Old Mar 12, 2008 | 07:01 PM
1redTA's Avatar
re
I believe that a vortec p/u cam is the same as the one in a caprice/impala minus the pin length. do a search on full size chevy.... Art
Old Mar 12, 2008 | 10:50 PM
ZZ's Avatar
ZZ
I have one in the 305 in my 88 Camaro.
Old Mar 13, 2008 | 12:15 AM
Bersaglieri's Avatar
My buddy seems to have wiped out the cam in his 350 Vortec K2500. He's asking for my stock LT1 cam. I'll let you know how it works, I dont see any problem.
-Dustin-
Old Mar 13, 2008 | 01:18 AM
ZZ's Avatar
ZZ
He'll need to cut the guides down a bit, I think max lift on Vortec heads is .460" That's not a lot of wiggle room. Might want some better springs too.
Old Mar 13, 2008 | 08:01 AM
curtis75's Avatar
I have a cam for a early gen I motor that makes it a roller (comp retro-fit kit), will it work in an LT1
Old Mar 13, 2008 | 01:07 PM
mdacton's Avatar
you sure? I think the lifters might be too short and hit the bosses...
Old Mar 13, 2008 | 08:20 PM
blown94's Avatar
better springs are a given. can anyone confirm the heads might need modified for higher lift? Probably looking at something in the .550 lift range witha a duration around 220*
Old Mar 13, 2008 | 09:07 PM
My Iroc Z28's Avatar
Common cam mod for the vortech trucks & Suv's are the LT4 cam or a factory cam from the Impala/Caprice. Some feel the LT1 f-body cam won't provide enough tq to help move the truck.
Do a search over on fullsizechevy.com
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
Queens94z28
Nov 20, 2014 06:03 PM
