LT1 A/C high/low pressure switch?
Old May 30, 2006 | 12:28 PM
detroit1994z28's Avatar
Does anyone know where exactly the high /low pressure switch for the A/C is? I have a good idea but not sure if it's one of the two. If anyone can possibly send me pictures that would be great. I'm thinking that is causing my A/C compressor to freeze up. - Mike
Old May 30, 2006 | 12:32 PM
Re: LT1 A/C high/low pressure switch?
The pressure sensor is here. I think some early cars also have a sensor on the low side pipe.
Old May 30, 2006 | 01:16 PM
I thought that was the pressure switch but I was not 100% sure. Thanks again buddy - Mike
Old May 30, 2006 | 01:35 PM
rngilliland's Avatar
The small line is the high pressure line. I don't think the high pressure switch would have anything to do with freezing problems. Some a/c systems use the low pressure switch to cycle the compressor to prevent freezing. The LT1 has a temperature probe in the evaporator and I have always assumed that is what was used to cycle the compressor but I may be wrong. I had a problem with my 94Z freezing a few years ago and the a/c shop replaced the expansion valve. That fixed the problem but I always wondered if that was the actual problem or if just recharging it would have fixed it. Low refigerant can cause the evaporator to freeze. If you havn't done it yet I would get the charge checked.
Old Sep 6, 2007 | 12:16 AM
stephenspann27's Avatar
how did you get yours fixed? I replaced my a/c lines (due to a leak) expansion valve and dryer, and now I"m having this freezing problem. I started with two cans in.. now I have three.. My guages read 45/250...
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
Z28countrymama
Jan 22, 2015 02:50 AM
Jason Short
Jan 19, 2015 06:34 PM
Jul 4, 2005 05:00 PM
