lt1 build help
Old Dec 13, 2011 | 11:55 AM
twistedbowtie's Avatar
lt1 build help
im building a mild build for my 94 z28. i have a new set of stock replacement rods. a block to have machined. ive found a set of pistons that are new in the box but it says they are 383 pistons. can i use the pistons on a stock crank build? if not if i brought a 383 crank is it possible to use the stock connecting rods? thanks Dustyn
Old Dec 13, 2011 | 12:26 PM
Kevin Blown 95 TA's Avatar
Re: lt1 build help
You need to see what the compression height of the pistons is, and that will tell you if you can use your rods for a 383 build, but the pistons are going to be too short for a 350 build with stock rods and with longer rods compression might still be too low..
Old Dec 13, 2011 | 01:00 PM
Re: lt1 build help
okay ill check on that thanks a lot
Old Dec 13, 2011 | 07:40 PM
Re: lt1 build help
this might help you
http://holley.com/data/TechService/T...n%20Height.pdf
page down to where it says Small Block Chevy Compression Height and it has a matrix for rods vs. strokes and gives compression height.
transam_388
Mar 15, 2015 11:53 AM
Moshbmx1
Jan 20, 2015 03:27 PM
Jrlt1
Jan 3, 2015 07:38 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
