LT1 bogs under acceleration
Old Jun 18, 2011 | 09:49 AM
  #16
Sleepy_Z's Avatar
Re: LT1 bogs under acceleration
I think someone mentioned about checking the opti wiring. Have you checked it to see if there's any damage, corrosion? I’d take a look at the other connectors too; maybe one of them isn't making a full connection. My opti harness was missing the clip to secure it and would work its way out.
Old Jun 18, 2011 | 12:29 PM
  #17
mj1993z28's Avatar
its a new unit MY1994Z28 and it came with a new wiring harness. I have been told a bad ignition module or coil could possible make the car read 36 as if it is the distributer. no saying it cant be distributer but i dont want to waste anymore time or money
Old Jun 18, 2011 | 10:35 PM
  #18
mgbadboyz's Avatar
Originally Posted by Injuneer
Here's the code list specifically for the OBD-I (93-95) LT1. Find a code that indicates a misfire:
http://shbox.com/1/Dtcs.htm
Misfire detection was added in OBD-II in the 1996 model. To do that, they had to add a crankshaft position sensor. The PCM monitors the irregularites of the rotational velocity of the crank, comparing those irregularities to the known pattern for an engine without a misfire.
Not saying ur wrong. Like i said, it was my teacher, and i guess he just got lucky, or knew what it was right away.
But your coil could definatly cause that problem. Im not 100% sure on the code 36 for it but a coil will cause a car to run fine for a minute then start backfiring and misfiring.
Old Jun 19, 2011 | 10:01 AM
  #19
Appears you have the All Ignition Products (AIP) Opti. Wouldn't be unusual for it to be bad right out of the box, or to fail after a short period of time.
It's my understanding that DTC 36 is set when the PCM counts less than 60 (OBD-I) or 80 (OBD-II) high res pulses between each low resolution pulse, and the condition persists over several continuous periods.
Old Jun 19, 2011 | 08:46 PM
  #20
mj1993z28's Avatar
yeah injuneer im thinking it is bad they are willing to replace it ... which still is annoying i just want my money back really and just wait another 6 months and just drop the 500 cash on a ac delco and be done with it, but i think im going to give it one more chance since they charge a stock fee or something to give me my money back.
Old Jun 22, 2011 | 07:23 AM
  #21
mj1993z28's Avatar
If there are anymore ideas from any please let me know all info is good info
armedtrigger
Feb 24, 2015 08:30 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
transamtom
Sep 11, 2002 04:28 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Brady
Jul 29, 2002 10:30 PM
