LT1 backfires when idles and then WOT
Old Apr 26, 2005 | 07:50 PM
SUTTERERMAN85's Avatar
I just rebuilt my engine and i bought the car not running. it replaced the IAC it was F'd up and my car ided at like 1800 rpm. now it idles right but when it is idleing and i give it WOT it will backfire throught the intake. but on the upper rpm's it seems to run ok. any ideas? if i give just a little throttle slowly it seems to be ok. could really use some ideas from you guys. thanks
nick
Old Apr 26, 2005 | 07:55 PM
MadKilla's Avatar
Re: LT1 backfires when idles and then WOT
When I rev my engine I also will occasionally get a backfire pop through the intake. No one has ever been able to tell me what it is.
Old Apr 26, 2005 | 07:59 PM
mine does it every time
Old Apr 26, 2005 | 08:00 PM
MadKilla's Avatar
Mine will do it consistently for weeks. Then will stop for a while. Weird.
Old Apr 27, 2005 | 09:06 PM
i still have the problem guys. any ideas would be great
Old May 1, 2005 | 07:50 PM
ItsfSSt's Avatar
I had that problem before, turns out it was my fuel pump, my pressure would drop below 10 lbs at times, it backfired, was a little harder to start in the mornings, but drove fine, something to check anyway.
Old May 29, 2005 | 10:05 PM
94ltwonz28's Avatar
mine does the same thing if its at idle and I floor it real quick it will pop on the intake side did it stock and does it with moroso cold air and flowmaster.
Old May 29, 2005 | 11:46 PM
baddboy1705's Avatar
if its the same "popping" that i think your talking about, I dont think Ive ever heard an LT1 that didn't, im not sure what it is, but ive been told that it might have to do with the way the cats were designed... just a thought
Baddboy1705@aol.com
Old May 30, 2005 | 10:33 AM
turns out it was my fuel pump. i only had like 12psi when it was ideling. guess it was a lean back fire everytime. well thanks for the help guys.
Old May 30, 2005 | 08:10 PM
94ltwonz28's Avatar
[QUOTE=baddboy1705]if its the same "popping" that i think your talking about, I dont think Ive ever heard an LT1 that didn't, im not sure what it is, but ive been told that it might have to do with the way the cats were designed... just a thought
every lt1 ive owned poped when you reved it up pretty high and let off, it would pop about 8 times on the way back down on the exhaust side, this stopped on my first lt1 when I put a cam in it.
this other pop im talking about does it if you are at idle and tap the gas real quick, it will pop the instant you mash the gas on the intake side.
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
F(ast)-body
Feb 26, 2003 09:05 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
smacz28
Aug 6, 2002 01:51 PM
