compression readings( are these good or bad)?
Old May 30, 2005 | 10:16 AM
Fbody1's Avatar
cyl#1 215 psi
cyl#3 210 psi
cyl#5 230 psi
cyl#7 230 psi
cyl#2 208 psi
cyl#4 227 psi
cyl#6 214 psi
cyl#8 210 psi
are these #'s good for 11.4 comp ratio?
Old May 30, 2005 | 10:32 AM
ZMAN Z28's Avatar
Re: compression readings( are these good or bad)?
Yes they look good to me. As long as they are all within a few of each other, you are fine on compression.
Z
Old May 30, 2005 | 06:08 PM
Fbody1's Avatar
thanks ,I am having some problems with oil getting to the combustion chamber some how , thought it was the rings or mabey the valve guides/seals ? any opinions anyone?
Old May 30, 2005 | 08:54 PM
ZMAN Z28's Avatar
If its valve guide seals, you will put out a pretty good puff of smoke upon starting the car. It will be more pronounced in the morning or when the car sits a long time.
Z
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
