LT1 alternator questions...
Old Aug 11, 2003 | 01:57 PM
chucks97ss's Avatar
First off, what is the stock amp rating on a 97 alternator? Secondly.... has anyone messed with using a smaller sized alternator to fit tall valvecovers? I've got about - half inch of interference right now.... I was wandering if maybe the corvette accessory brackets would fit the F Body's? Because they mount everything low right? Just not sure if it would fit the k member... So if anybody know's anything about that, that would be great as well...
Chuck
Old Aug 11, 2003 | 02:01 PM
predator's Avatar
i believe they came with 108 and 140 amp
Old Aug 15, 2003 | 11:15 PM
chucks97ss's Avatar
So could I run something like a 120 amp and be fine? What's the reason behind the 140 amp compared to the 108?
Chuck
Old Aug 15, 2003 | 11:24 PM
93formula's Avatar
the police code camaros had the bigger amp.
Old Aug 15, 2003 | 11:26 PM
chucks97ss's Avatar
So all of our normal LT1 Z28's have 108 amp alternators?
Chuck
Old Aug 16, 2003 | 10:55 AM
Mtrhds94Z's Avatar
No most LT1's I have seen are 140 amp.
CS130 is 105 amp and came on the V6's
CS144 is 124 or 140 amp and came on the LT1's, and share the same housing.
The 124 amp has a metal fan and a bolt attaches the red BAT pos cable.
The 140 amp has a plastic fan and uses a nut on a stud to attach the red BAT pos cable.
Old Aug 16, 2003 | 11:20 AM
chucks97ss's Avatar
Oh ok... yeah, mine is a 140 amp version. I think Powermaster will probably have one that works. I emailed them last night. We'll see what they say.
Chuck
HectorM52
Jun 23, 2016 08:42 PM
Noer
Feb 28, 2015 11:29 AM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
