LT1 911! Overheating, coolant spilled out of reserviour spout
Old Oct 19, 2004 | 07:27 PM
  #31
Dee94Z28's Avatar
Re: LT1 911! Overheating, coolant spilled out of reserviour spout
Hey check if you have a small hole in the radiator I had the same problem and there was a hole an inch below the the radiator cap (pin size hole)
Old Oct 19, 2004 | 07:54 PM
  #32
ShawnMacAnanny's Avatar
Originally Posted by Jasonz28camaro
DON'T start your care with out the thermostat in it. You will be sorry. I had problems similar to yours and tried the very same thing and the PCM shut the car down causing lots of problems once I put the stat back in. OBD1 and OBD2 have pressure sensors of some kind.
I flush my coolant without the thermostat all the time. You run the engine and a garden hose. Don't drive without your thermostat though becuase it's bad for your oil.
calaban
May 18, 2020 06:43 PM
Sandersen511
Jan 13, 2015 03:49 PM
NewsBot
Dec 30, 2014 09:40 AM
NewsBot
Dec 28, 2014 06:20 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
