LT1 / 700R4 / Stock stall / cc305
Old Feb 6, 2004 | 05:49 PM
lt1g3n's Avatar
I'm not looking to get a new transmission right now, the trans is in good shape as far as I know, i've never had problems with it. It's the 700R4, with stock stall.. My cam just arrived (cc305) and I was wondering if my transmission will handle the lt1 with this cam. On a few posts some people questioned why I was using this trans.. but right now it's my only choice , and only trans I have.
What can I expect from it? Is it going to reduce my rwhp by alot?
Old Feb 6, 2004 | 06:02 PM
nitropatch's Avatar
no it will not affect your rwhp the 700r4 is the same as the 4L60E just that yours isnt electric thats all, the cam will work good with that transmition, the custom cam i have is alittle bit bigger then the cc305 so i will work good with yours in my opinion.
Old Feb 6, 2004 | 06:31 PM
12SCNDZ's Avatar
I had a 10.5" 3200 stall behind my stock cam/motor. When I did the CC305 and ported heads, I had to go with a 9.5" 3800 stall. Your stock stall isn't going to like the CC305.
BTW, I've got a 700 in mine, too...It's spent 3 seasons in the 12's...High 12's for the first 2, and low 12's last season. I've built 700's for mid 10 second cars.
Frank
All-Trans Transmissions
Old Feb 6, 2004 | 06:36 PM
lt1g3n's Avatar
cool, thanks for the input, u got a place where i can order a nice stall that you think will hold up for a long time?
Old Feb 6, 2004 | 06:41 PM
12SCNDZ's Avatar
ProTorque Converters...Both my 3200 and my 3800 have been ProTorque converters.
http://www.protorque.com/index2.htm.
With the current set-up, I'm pulling 1.67 60 ft. times with a completely stock suspension.
Frank
Old Feb 6, 2004 | 06:44 PM
12SCNDZ's Avatar
BTW, I build automatic transmissions for a living (14 years). A shop I worked at for 7 years has it's own converter shop. This gave me the luxury of seeing what's inside many manufactuerers converters.
That being said...There are only 2 that I'd recommend. ProTorque and Precision Ind. (Vigilante).
Frank
Old Feb 6, 2004 | 09:59 PM
lt1g3n's Avatar
excellent, thanks alot
Old Feb 7, 2004 | 12:55 PM
96LT14u2Nv's Avatar
im not a big advecate (sp) of the 700r4, they never seemed to stand up to the power to me. i would definately invest in a converter tough.
Old Feb 7, 2004 | 02:03 PM
12SCNDZ's Avatar
Obviously, you've never had anyone build you a GOOD 700. You'll blow that T56, or the clutch apart before my 700 will come apart. 700's get a false bad rap because there are alot of idiots out there that claim they can build them correctly.
Frank
Old Feb 7, 2004 | 03:08 PM
nitropatch's Avatar
i would take the 4l60e over the 700 any day, the 700's just arnt as strong as the 4l60e's but they will hold up to a cam install for a little while.
Old Feb 7, 2004 | 03:48 PM
12SCNDZ's Avatar
Um...There are NO strength differences between a 700 and a 4L60E. The 2 are almost identical internally. The only difference being the 700 is governor controlled (hydraulically shifted), and the 60E is computer controlled. Very early 700's had some strength issues because of the input sprag design, and they only had 27 spline input shafts. Later 700 ('87-up) share many of the same internal parts as a 4L60E. Input shafts, input drum, planetaries, ring gears, output shafts, clutches, steels, and the band are all interchangeable. About the only parts that can't be interchanged are the cases, valvebodies/control pieces, and the pump...None of which are strength related.
Frank
Old Feb 7, 2004 | 03:50 PM
nitropatch's Avatar
then why do you hear more 700 brake then 4l60e's??
Old Feb 7, 2004 | 03:57 PM
lt1g3n's Avatar
they are the same trans , but the 700 isn't computer controlled.. maybe because most of the 700's are rebuilds by idiots, like that other guy said
Old Feb 7, 2004 | 03:58 PM
12SCNDZ's Avatar
You probably hear more about them burning up, not breaking...Remember, they haven't made 700's since 1993. So, the newest one's are 10 years old. The original 700 trans in my '93 Z lasted 90,000 miles.
700's are actually a little better suited for racing, because you don't rely on a computer to shift it. Although, I can claim one 60E that I built that runs consistant 11.0's @ 124 MPH, in DRIVE!
700's are easier to retro into cars that originally had 6-speeds, or any other transmission. I have one 700 in an AC Cobra replica with a 350 ZZ4 crate motor that runs low 11's.
Frank
Old Feb 7, 2004 | 04:10 PM
nitropatch's Avatar
i see, i am goin low 12s with it in drive as well i will get to the 11's with some more upgrades
DirtyDaveW
Dec 1, 2016 05:37 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
