lt1 in 69 camaro
Old May 8, 2007 | 12:07 PM
pugads650's Avatar
lt1 in 69 camaro
i have a lt1 with a 4l60e out of a impala ss thats going into a 69 camaro. heres my question i want to delete alot of the wirring since i dont have to smog it i just needs it to run the ignintion and and the fuel injection and the alternator any help will be greatly appreciated thanks.
jonathan
Old May 8, 2007 | 12:25 PM
ChevalierSS's Avatar
The easiest thing to do would be to leave the harness as-is, and send to computer off for a mail order tune. I thinks it only $75 to disable all of the emission stuff.
If you can find a local tuner they may be able to do it cheaper, my AIR delete, Skip shift delete, and 4.10 gear programming cost $30
Old May 8, 2007 | 01:40 PM
Greg Nolte's Avatar
Try this guy. Andrew K. Mattei [amattei@mindspring.com]. great guy and generally hangs out in the computer diagnostic section. The wiring is all BS. I subcribed to All Data and got the diagrams and locations, run two cpoies of everything and keep a log of everything you buy. You'll need it for servicing it down the road. A lot of the wiring is ABS and the such and not needed. Don't for get to program out the security key
Old May 8, 2007 | 02:05 PM
Heatmaker's Avatar
Advanced Member
I think fast offers a kit that's ideal for what your doing. It is a bit cleaner than dealing with cubersome wires that you don't need.
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
