Lt1 396
Old Nov 2, 2006 | 10:22 PM
Bad boy's Avatar
Smile Lt1 396
I have a lt1 396 with 190 Afr heads Long tube headers, 245 254 dur comp cam Th 350 w 9 inch coan convertor with ford motorsport 30lb injector with 28 inch tires. Do you think I need bigger injector. How fast doyou think the car will run. Right now I have a mail order Ed wright program. My compression ratio is 11.25:1. I am running stock fuel pressure with stock reg. What do you think
Old Nov 3, 2006 | 09:52 AM
The 30# injectors are only good for 450flywheelHP if you hold the duty cycle to 85%. You should be well over that with the specs you list. You probably need either 36's (530HP) or even a set of 42's for max headroom.
Old Nov 3, 2006 | 10:11 AM
fast 93 z's Avatar
I agree with Injuneer. 42's would work well for your combo.
Old Nov 3, 2006 | 11:12 AM
NVetro's Avatar
Another vote for 42lbs injectors. I think they are in the 60ish-65ish % Duty Cycle Range on a 400-430rwhp NA 383.
Old Nov 6, 2006 | 09:59 PM
Bad boy's Avatar
Bump
pimpss96
Feb 12, 2015 01:28 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
