LT1 383 Stroker
Old Jun 16, 2004 | 12:20 PM
DarkRider's Avatar
LT1 383 Stroker
I have a bare block Lt1 right now and I am wanting to build me a 383. How many people use their 2 bolt main motors to make a 383. Basically what I am asking is will a stock Lt1 b lock hold up to that power. Also is it possible to make the block 4 bolt mains.
thanks
Josh
This will be my first motor build so If you can think of anything else I need to know don't bother speaking up.
Old Jun 16, 2004 | 01:37 PM
kmook's Avatar
Advanced Tech Moderator
This should be discussed in LT1 Tech, transfering. Thanks.
Old Jun 16, 2004 | 01:42 PM
a mean 94z's Avatar
You'll have no problem with the 2 bolt. But if you are really worried about it, you could always splay the 2 bolt and it would be stronger than a 4 bolt....
2 bolts are good up to like 600, I'm not sure. I've never heard of anyone having a problem with the 2 bolt.
Old Jun 16, 2004 | 01:50 PM
Revolutionary's Avatar
It is not a huge deal to make a 383 LT1 engine. There are a few things that are important to note. First, the 2 bolt block will easily handle 600+hp with ARP main studs. Second, you will be money ahead to use a forged steel crank as the cast cranks will not balance on the front half without adding Mallory metal which about equals the price of upgrading to the steel crank. Third, not only do you need to clearance the block where the rods will hit but unless you get a small base circle cam, you will need to clearance the upper corner of your rods by the bolt head. Finally, on the LT1 engines you must make sure you get the correct year woodruff key for the timing gear on your crank or you will need to notch the damper hub to fit a normal SBC key. Shoot me an email if you have any more questions.
Old Jun 16, 2004 | 02:06 PM
v7guy's Avatar
the amount of clearancing will also depend on the rods you choose, leght, H or I etc
Old Jun 17, 2004 | 08:37 PM
DarkRider's Avatar
what is H or I, as far as the rods go I thought you just had to get 3.75 rods. Or am I completely wrong?
thanks
Josh
Old Jun 17, 2004 | 08:43 PM
DarkRider's Avatar
Are there any good manuals out there for bulding a 383 stroker.
thanks
Josh
Old Jun 17, 2004 | 08:56 PM
97SS0594's Avatar
H= h beam rods
I=Ibeam rods
your 3.75 is your crank, with a stroker some go with 5.7 inch rods, some go with 6 inch rods, and theres another size its like 5.85 or something
Old Jun 17, 2004 | 09:34 PM
ninetythreez's Avatar
I just left Books-A-Million. There were several 383 Chevy build books there in the transportation section. Good luck.
I didnt know that about the cast cranks. Is that a factory 400ci or a 1 piece cast for LT1 cranks that has to have metal added? A guy tried to sell me a CAST 1 piece rear mn seal LT1 383 crank yesterday for$200.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
