Lt1 / 350
Old Nov 27, 2004 | 06:00 PM
wicked cmr's Avatar
Lt1 / 350
I had an LT1 motor all built up and as it was getting its final tuning/timing, everything was perfect, then went to drive it around and it threw a rod , didnt bust through the bottom of the pan , but did really mess up my block, and shatter some pistons, opened the pan up and there was a nut missing on one of the connecting rods damn that sucked, and this was manufacturered/bought new =(, but any how i was just curious what can be transferred over to use if i wanted to use an old 350 block, gen1 instead of 2. intake / heads work ? no? Thanks..
Old Nov 27, 2004 | 09:35 PM
Red_94Formula's Avatar
Re: Lt1 / 350
The entire bottem end is the same as sbc gen 1. The heads really arnt. They would need a lot of costly work. Roller rockers would work.
Old Nov 27, 2004 | 09:47 PM
My Iroc Z28's Avatar
Re: Lt1 / 350
nothing will work with a older style block the heads are set up for reverse cooling and the older blocks are not, you can use the internals except the cam and maybe the crank if the the block has a 1 piece rear main seal..
Old Nov 27, 2004 | 09:56 PM
ScreamingChicken's Avatar
Re: Lt1 / 350
transfer your old parts to the trash can.
Old Nov 28, 2004 | 01:13 AM
wicked cmr's Avatar
Re: Lt1 / 350
really? think it effected everything?
camy 1993
Feb 1, 2015 07:16 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jrlt1
Jan 3, 2015 07:38 PM
4586
Dec 6, 2014 05:20 PM
